AndreasSvensson
Mar 03, 2016Aspirant
Failing RNV1-S2-0000 - Drives don't spin up
This morning when I woke up, my NAS wasn't working and I could smell a burnt smell. It still powers on, but it appears that the drives don't spin up. Currently the power light is pulsating and all th...
- Mar 11, 2016
*edit* found your device on the server.
I am making an adjustment -- can you check and see if it some of those files are accessible again?
kohdee
Mar 10, 2016Administrator
Maybe a capacitor blew? Can you get the device in tech support mode?
- AndreasSvenssonMar 10, 2016Aspirant
Note in the discussion previously, this is a completely separate (by same model) of encasement. I just moved over the drives from the previous encasement and is still experiencing the exact same behavior, but I will try to get it into tech support mode.
- kohdeeMar 10, 2016Administrator
I understand, but if the device boots into tech support mode, then it is possible to see if something in the hardware is bad, which causes RAIDar to look like that. Also from Tech Support mode, able to analyze the quality of the disk. If it is something corrupt in the OS, that's also addressable by TS mode. Check RAIDar once the device is in TS mode.
Okay, good. Then we are on the same page.
Just to confirm, for tech support mode:
1) Power it off.
2) Press the power button and hold it for 15 seconds until disk leds flash 3 times
Can you please confirm?
