b3nb_123
Nov 30, 2022Aspirant
Fastest Transfer setup - twin LAN cables or USB?
I have a READYNAS 104, it's been working fine for me for my home office, with a pair of twin drives running in RAID. (I've actually just bought a used 106 that I haven't yet set up, as I decided to add a couple more drives, but I'm guessing the functionality is identical?)
However, I noticed there were two LAN cables on the back, and wondered if I could better use the connections for faster transfer? If I ran two network cables to my switch, how would I connect my PC. with the same speed? What extra cards etc would I need. Or is there little to be gained?
I seem to remember from my research when I first set this up years ago, that USB connection to the PC won't work? Or am I wrong?
No such model, so you should look into that further.
6-bay OS-6 NAS models include the
- RN316
- RN426
- RN516
- RN526
- RN626
There are some 6-bay 4.2.x ReadyNAS also
- Ultra 6
- Ultra 6 Plus
- Pro 6
These units can be converted to OS-6 (but some other 4.2.x cannot be, so it is good to confirm the model).
There is little to be gained in almost all home situations - especially with the RN100 series, which is limited by its CPU and memory - generally not the network.
What transfer speeds are you seeing? (Best to look at this during a large file transfer - a couple gigabytes).
Typical speed for an RN104 is 60-70 megabytes/second. Your 6-bay NAS should be faster (around 100 megabytes/second).
Correct. The USB connection is for a UPS, or for external USB drives (for instance for backup). It won't work if you try to connect it directly to a PC.
- b3nb_123Aspirant
Sorry, RN31662D - That was me lazily replacing the 4 for a 6!!!!
b3nb_123 wrote:
RN31662D
The RN316 bit is what matters. The 62D at the end means that Netgear supplied six 2 TB desktop-class drives with the system.
I recommend testing the NAS by installing a spare disk, and use that to make sure all 6 bays are functioning. Power down the NAS, shift the disk to the next bay, then power up, and make sure it boots.
While you are at it, update the firmware.
You can directly migrate your disks to the RN316:
- You do want to match the firmware (easiest to update both NAS to the latest). If the RN104 firmware is old, make sure you install the recommended intermediate firmware as you upgrade.
- Uninstall any apps on the RN104 before you migrate
- Power down both NAS, and move the disks (preserving slot order).
- Reinstall any apps you still want to use.
If you have no backup plan in place for your NAS, you could also repurpose the RN104 as a backup NAS, and get new disks for the RN316.
