TWilson
Oct 31, 2015Aspirant
Feature Request - Report Installed Memory on OS6 System Tab
I might be overlooking it, however I cannot find the amount of installed memory reported anywhere in the ReadyNAS OS6 web interface. The amount of installed memory is reported on the old RAIDiato...
BrianL2
Nov 01, 2015NETGEAR Employee Retired
Hi TWilson,
This information is not available in the UI but can be seen in the device logs. I suggest that you contact our support team to create ticket for this feature request.
Kind regards,
BrianL
NETGEAR Community Team
mdgm-ntgr
It would be nice to see this, but there are a few things worth noting:
1. We don't support 3rd party memory upgrades and some of our models have RAM that is soldered on (i.e. not replaceable).
2. It is expected to see all the memory in use. We use memory for caching to improve performance and free it up when needed. If you think you don't have enough memory installed you should check to see if the memory is swapping.
- TWilsonNov 01, 2015Aspirant
mdgm wrote:It would be nice to see this, but there are a few things worth noting:
I don't have any memory issues or concerns regarding 3rd party memory upgrades. I have multiple NAS units and would find it nice to able to view basic system info on each without having to run a shell command or open logs. I can live without it....
- kohdeeNov 02, 2015NETGEAR Expert
RN100: 512 M of RAM, soldered
RN200/212: 2 GB of RAM, soldered
RN310: 2 GB of RAM
RN516: 4 GB of RAM
RN716: 16 GB of RAM
RN2120: 2 GB of RAM, soldered
RN3130: 2 GB of RAM
RN3138: 4 GB of RAM
RN3220: 4 GB of RAM
RN4220: 8 GB of RAM
