HERBIEO's avatar
HERBIEO
Feature Request: option to set power on event
Although the power timer is a great feature this could be improved, i would like to see an option to manually set a power on event when using the graceful shutdown from the dashboard, is this possible ?.
1 Reply
  • Possible, yes. Will it be added, who knows.
    I still don't know why the power timer ON only works if power timer OFF, not when manual shutdown occurs. It is just a script that runs on shutdown that sets the RTC alarm.
ProSupport for Business
