landogarner
Sep 28, 2007Aspirant
File Manager inside Readynas
It would be nice to be able to do file manipulations directly inside ReadyNAS GUI. We have millions of files on our ReadyNAS that come from security cameras and it takes hours to delete them over L...
looter
Apr 03, 2008Aspirant
[/quote]
The HTTP file manager will run as user "admin" even if you logged in as another user. It's a limitation due to the service. But the effect is if the file is owned by another user and "admin" does not have access to it, you'll have some problems. Perhaps try using dbott67's suggestion of using a FTP or SCP client. For SCP, you would need to enable SSH support however.[/quote]
Any way to access a private home share via HTTP file manager?
