JimND
Jan 08, 2009Aspirant
Finding and deleting duplicate files.
I've only just got a readyNAS NV+, after years of using various sizes of usb-connected disks, and now I need to rationalise the thousands of files I've accumulated. Since there are lots of duplicates,...
parkerc
Oct 24, 2011Aspirant
Hi Antony09, not sure if you are on commission for that post, but if not you must only have used it with a few files, because the people I have spoke to find large NAS searches impossible as the toolslike the one you've suggested freeze due to the amount of files it has to go through.
An netgear add-on that does not require SSH etc, which can do a small amount of indexing on the NAS itself pulling key attributes would be hugely usefull.
