VulpesVulpes
Aug 21, 2017Follower
Finding Readynas file structure
Hi! Okay this might be the dumbest question you have seen posted here - be kind not IT background. I am tech savvy but this has me stumped Okay.... so I have been able to download things using t...
Aug 21, 2017Guru - Experienced User
VulpesVulpes wrote:
NAS. Data/Transmission/Downloads - Media Server can see but \\jp-nas\Transmission\Downloads is empty
IF you use the web admin UI, can you see the contents of the download folder? Did you try resetting the file permissions (on the file access setting page for the share).
VulpesVulpes wrote:
If I download something using a desktop to the NAS, I can't see it in the media server even when I point the thing to look at that folder. (Data/Volume1/MyDesktopDownloads)
You created a Volume1 share? Is your media server using SMB to access the NAS, or is it using something else (like DLNA)?
