grahamneve
Aug 18, 2019Aspirant
Firmware Upgrade to 6.10.1 Loses DLNA/Media Server Capabilities
Hi all, please excuse me if this has been covered earlier. I have been using an RN102 as a media server for around 5 years, streaming through various devices such as panasonic TVs etc. This has worke...
Voyager62
Aug 24, 2019Aspirant
Hey grahamneve, I had a similar problem in that my Nvidia Shield couldn't see either Netgear server. Even though ReadyDLNA was enabled, I wasn't able to stream anything to the Shield. I couldn't find an answer anywhere other than that the Shield only supports SMB 1, but this was already enabled in the SMB Plus settings.
What I finally discovered is that, under the SMB settings, "Legacy Windows Discovery" needs to be enabled for devices that don't support the newer discovery method in Windows 8 and above. See the attached screenshot. Give that a try and see if that solves your problem.
- grahamneveDec 15, 2019Aspirant
Been nearly 3 months now and no answer from Netgrear. Plex not working because the server is 'not powerful enough' to play the movie. Supprot form Netgear is non existant....keep escalating it but no courtesy of a reply. Appalling!
- schumakuDec 16, 2019Guru - Experienced User
Voyager62 wrote:... Nvidia Shield couldn't see either Netgear server. Even though ReadyDLNA was enabled, I wasn't able to stream anything to the Shield. ... What I finally discovered is that, under the SMB settings, "Legacy Windows Discovery" needs to be enabled ....
The Legacy Windows Discovery control is enabling the ability to discover and resolve the host name by systems not supporting WSD, the protocol related is NetBIOS, and it's IPv4 broadcast based. The Shield does require NetBIOS for SMB share/folder/file access.
This is completely unrelated to DLNA/UPnP AV infrastructure (DMS, DMC, DMR - digital media server/control/renderer) where the SSDP is used, a Multicast based protocol.- Voyager62Dec 16, 2019Aspirant
This is completely unrelated to DLNA/UPnP AV infrastructure (DMS, DMC, DMR - digital media server/control/renderer) where the SSDP is used, a Multicast based protocol.I don't know why it took you 4 months to reply to my post, but whatever you're trying to say isn't true in my case. I HAD to enable Legacy Discovery for the Nvidia Shield to see my Netgear servers. There was no other option that worked, whether or not all your gibberish is true. I was replying to the OP about how I managed to get my RN214's to work with my Nvidia Shield, nothing else. If you don't need Legacy Discovery enabled, the kudos for you.
- schumakuDec 17, 2019Guru - Experienced User
The point is that if you need the legacy discovery enabled that your Shield is using shared folder access (by SMB protocol) and not the subject DLNA/UPnP AV Media Server protocol.
