zekzek
May 08, 2023Aspirant
format hard drive no longer used in readynas raid 1
Hello everyone - I did some digging around and couldn't find anything specific on this. I have a ReadyNas 102 on RAID 1 with 2 x 2TB. I originally had 2 x 1TB on RAID 1. I'm looking to repurpose th...
- May 09, 2023
zekzek wrote:
I used an external sata connector to connect the 1TB hard drive to my laptop and in Disk Management, its not initialized. When I try to initialize it, I get an error that states: data error cyclic redundancy check.
Which means something has failed - likely either drive has failed or the USB SATA adapter. Though also check that the cabling is secure (both data and power).
You might try testing the drive with vendor tools (Seatools for Seagate, Dashboard for Western Digital).
FWIW, I suggest zeroing the drive before resale instead of reformatting. Seatools has an test that will do that (though it might not be enabled with non-Seagate drives). There are other free tools that do this as well, including the AOMEI partition manager.
zekzek wrote:
I read that I'd need mdadm and btrfs to get the drive to be able to be read in windows.
You are confusing reading the files on the drive with formating. Windows doesn't recognize the file system, so it won't mount it. But it's still just a SATA drive, so you can initialize, format, etc.
May 08, 2023Guru - Experienced User
zekzek wrote:
(Who knew you couldn't connect them to your windows laptop to format? not this guy)
You can.
zekzek
I used an external sata connector to connect the 1TB hard drive to my laptop and in Disk Management, its not initialized. When I try to initialize it, I get an error that states: data error cyclic redundancy check. I read that I'd need mdadm and btrfs to get the drive to be able to be read in windows.
- StephenBMay 09, 2023Guru - Experienced User
- SandsharkMay 09, 2023Sensei
You have to do more than format. You need to delete the partitions, re-partition, and then format.
Yes. I was assuming zekzek had deleted the partitions from Windows Disk Manager (because he said the CRC error happened when he tried to initialize the disk).
- zekzekMay 09, 2023Aspirant
I think the drive has failed. You were right that its just a sata drive that windows should recognize just fine. I had another identical 1TB hard drive that I plugged into the same sata cable and this 2nd drive fired up just fine and I'm currently formatting it.
I suspect that the first sata cable I used might have corrupted my original 1TB drive 😞
