LPC
Sep 15, 2015Star
Fresh Costumer to ReadyNAS 104, quick review and some questions...
Hello dear friends... For some years now, i have being using home NAS to Cloud Services, since the BITCASA Fiasco, where i lost some very important files that where irreplacable... Being a very cau...
Sep 16, 2015Guru - Experienced User
LPC wrote:
...I think the problem is on the DNS...
Yes. That can't be blank.
The answer might not be 192.168.1.1 though. You should check to see what DNS servers are being handed out by your router.
With Window you can find that out by launching cmd (in win7 just type cmd in the "search programs and files bar"). Then enter
ipconfig /all | findstr /R "DNS\ Servers"
That will tell you the right address(es) to enter there.
You can also safely enter Google's public DNS server addresses (8.8.8.8 or 8.8.4.4).
Truthfully, the best way is to keep the NAS set to DHCP, and reserve an address for it in your router.
...So for Link Agregation is need a configuration on the NAS and in the router... From your words is not worth it right?
I don't speak for Eskender :smileywink:
But frankly it's not worth it on the RN104. It's not fast enough to fill a single gigabit connection, so there's no benefit. The RN200 and above are fast enough, but even there you only benefit if you have multiple users accessing the NAS at the same time. Just connect one ethernet cable, and be done with it.
EskenderNG
Sep 16, 2015NETGEAR Employee Retired
Hello Paulo,
For cacti please use username: admin and password: admin. A password change will be required after that.
I am not using google drive myself so I am not sure if there is any external app that can be used. Maybe it would be best to post this question in a new thread to increase chances that other users will reply to this.
The 6.4.0 release will be for your device. Unfortunately, there is no email notification. Looking at the beta release notes there will be a share quota implemented:
“1. Share quota support. You can now set a size limit on a share.
* Note that the size limit will be enforced but not displayed from connected clients.”
I have copied your requests.
Bye,
Eskender
