LPC
Sep 15, 2015Star
Fresh Costumer to ReadyNAS 104, quick review and some questions...
Hello dear friends... For some years now, i have being using home NAS to Cloud Services, since the BITCASA Fiasco, where i lost some very important files that where irreplacable... Being a very cau...
LPC
Sep 18, 2015Star
Hello Askender!
Thanks for your reply...
Well i did change the channels on the router, to see if it work... if i put too high the Wifi don´t see the 5ghz channel...
Well at the time of the test nothing was using my 5ghz network, most if not all my devices are using the 2.4ghz (Tablet. smartphones and laptops).
The only devices that use the 5ghz network, are this computer (my work computer) and the minix android player, that was off on that time.
Suposelly i have 1300mbits of bandwith to work with, but at the time of the testing i was just using 400mbits, pretty low considering things... I checked my WAN capacity and it was at 30%!
So the problem must be on the router, NAS, route... If i plug a wired cable things start to look a little better, but not many, because i slower NAS have better performance that a better and more capable NAS (yours).
For the Record, i don´t have actived:
- Snapshots
- AV (is not usefull)
- Bit Rot
- Checksums
- Encription
- I don´t have any addon activated (Cacti is not usefull and i can´t sync to Gdrive with bittorrent Sync). The AV Plus addon is disable because the real time av is also disabled.
So If this is poor CPU capacity (i can´t really see it... there is no display for CPU and RAM usage)...
They more i use the NAS, the more i see its a good potential product, but with lacking execution on the software front...
Sorry but i must say what i see and feel...
- OS is still WIP, need much more refinements and its not that ready for SOHO prime time...
- Its lacking functional usefullness, better and easy options, better menu structure, more informative informations on the dashboard (top of the header for exemple).
- the lack of proper apps is a very big disavantage... Lack of online cloud services, lack of a proper AV app (one that allows for a interface with quarantine, and some usefull options for the costumer.
- Need of optimizations to the NAS itself...
- What is going on with that crazy cpu temps?
- HDD´s allways working on the 50c ???
- Lack of proper fan control
- No control to the front display (what is the point of having a screen that is allways off?)
Im an reasonable person, at i undestand that product do refine over time... but i need the product right now, not months from now...
Unless there is some assurance that problems, will be fixed, and more effort are made to enhance the apps, i will have to let this product go, and get a more madure and stable one...
Im pretty sad, because in the end i look at the NAS and i like what i see... i lke the design, i like the solid feel, i like the quality of the materials... That product is made to last! But o product that is made of hardware and software, both parts must be in equal sides...
And its not the case...
I will be waiting for some replys...
With my best regards,
Paulo Eduardo
CEO - Trignosfera
Sep 18, 2015Guru - Experienced User
All things being equal, RAID-1 is faster than RAID-5, and has a lower CPU load.
Your RN104 gigabit speeds are about right. The BTRFS file system has better data safety than the older EXT file system used by Synology (and older ReadyNAS). But there is also a performance hit, especially on writes.
WiFi is another matter. Never confuse the link speed (1300 max in your case) with real world performance.
You can expect to see TCP/IP throughput of about ~300 mbits if you are in the same room as the router. It drops from there. A nearby room will likely be 100-200 mbits, depending on conditions. These numbers are based on my own real-world measurements (and are measurements of network throughput, not a Network share disk test). If you are looking for an inexpensive basic throughput tester,TotuSoft's LanTester (bundled with their LAN server) costs $11. You'd run the server on a wired Windows 10 PC, and the client from your WiFi laptop (or desktop).
If you are in the US: Channel power for 2-digit channels was capped at 50 mw (3 digit capped at 1 watt) until the spring of 2014. If you have an "older" AC router like the R7000, you will get much more power out of the 3 digit channels. A router introduced in 2H2014 or 2015 should give the full 1 watt on the 2-digit channels.
If you are in Europe: Channel power is capped at 50 mw for all 5 Ghz channels.
Either way, if the geography is set properly in your router and in your Archer adapter, you should be seeing all legal 5 ghz channels if you are close to the router.
None of this explains the read wifi performance you are seeing for the RN104. If you have jumbo frames enabled on the RN104, I'd suggest disabling them, and retesting.
Also you will need more than one test to accurately gauge wifi performance. I happen to be monitoring my WiFi speeds at the moment (taking daily tests). There's a huge amount of variation - my results range from 96 to 184 mbits of throughput (all measurements taken from the same location. Repeating tests back-to-back often gives different results too.
- LPCSep 18, 2015Star
Hello Stephen...
Thanks for your reply and explanations...
In the end is the follow saying "we get what we pay for..."
And this is true on this matter... I appreciate all the support and direct line the company.
But i will be moving on to a more powerfull and faster NAS... If hardware was all that it was... i would purchase again a Netgear ReadyNAS.
But i do need more that the current ReadyNAS OS can do.
As so i will be moving on to the QNAP TS-453mini... I know... I know... its not the same price point, is not the same segment.
But i need a stilish and versatile NAS that can hold for some years... I will also keep a look on the NETGEAR future products and evolution of the OS.
And i trully wish NETGEAR can come forward in the future with more good and competitive products!
With my sincere regards to all the staff, i wish you all a productive and happy day.
Paulo Eduardo
CEO - Trignosfera
