childsy
Nov 12, 2016Aspirant
Front view (admin) does not load correctly.
Hi all. I am running a readynas nv+ v1 (hopefully that isn't a factor for this issue) and I preformed an OS reset which has given me default settings of 10.0.0.119 admin (user) netgear1 (pw). My issu...
FramerV
Nov 13, 2016NETGEAR Employee Retired
Hi childsy,
Have you tried clearing your cache?
As a last resort, you might want to try and back-up your most important data as well. Just in case we need to factory reset the ReadyNAS.
Nov 13, 2016Guru - Experienced User
Was SSH enabled before the reset? If so, does it function correctly?
