childsy
Nov 12, 2016Aspirant
Front view (admin) does not load correctly.
Hi all. I am running a readynas nv+ v1 (hopefully that isn't a factor for this issue) and I preformed an OS reset which has given me default settings of 10.0.0.119 admin (user) netgear1 (pw). My issu...
childsy
Nov 14, 2016Aspirant
Yeah it functions correctly. I can access the files by Explorer but can't see front view. I see in other posts people use commands. Are they using command prompt or something else? How do I clear the cache if unable to use front view?
JennC
Nov 14, 2016NETGEAR Employee Retired
Hello childsy,
FramerV was referring to browser cache that does not need to load FrontView, Please see this article.
Lastly, having SSH enabled could be the cause of your concern, it can be disabled from the backend. Last option you have is to factory reset, but you need to back up the data, We always strongly recommend to always have full backup, anyway.
- StephenBNov 14, 2016Guru - Experienced User
Well, maybe - but I see nothing on the thread that leads me to that conclusion.
If SSH is enabled and functional, then please do log into the NAS and see how full the OS partition is. The relevant commands are:
df -i
df -h
