Jellen
Jun 11, 2009Aspirant
FTPS or SFTP as option in Frontview backup
As you all know FTP is still one of the most common file transfer protocols used to backup or restore data from remote servers. This is however a huge security risk, FTP has no encryption, not on acc...
yoh-dah
Aug 19, 2009Guide
mjw wrote:
yoh-dah wrote: FYI, SFTP support is there automatically if you enable SSH access.
Hi Yoh-dah,
I have SSH enabled but no SFTP option is present when I select "Add a New Backup Job" in FrontView.
I want to use the ReadyNAS to backup my Ubuntu server machine (which can be accessed via SFTP but not FTP). One of the options for the backup source in the FrontView menu is called "Remote: FTP Site" but there is no option for "Remote: SFTP Site".
Please can you clarify how we should set up a backup via SFTP using the Frontview backup functionality?
Thanks,
Mark
SFTP server support is present on the ReadyNAS, not client, i.e. you can use a SFTP client to access data on the ReadyNAS. There is no SFTP support from FrontView Backup.
