mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
General Feedback on 6.2.3/6.2.4
This thread is a place to leave general feedback on 6.2.3/6.2.4
- rimmerhgAspirantTurning off the NAS that has become the Master Browser is not an option at this time as time as it is a production box at my clients site and is in use 24/7. as it is in a distance learning educational institution I would need to wait until there next Term shutdown.
Also I have spotted a issue with replication, the HOME share does not show in the selection and therefore is not being replicated. !!!! - mdgm-ntgrNETGEAR Employee RetiredIf you turn off the NAS that has become the master browser what happens?
- mdgm-ntgrNETGEAR Employee RetiredCan you send me the logs from the systems (see the Sending Logs link in my sig)?
- rimmerhgAspirantHi,
I updated 4 RND314 boxes to 6.2.4 from 6.2.2 and now have a problem with "Windows7 Pro" Computer browser missing 3 of the boxes and I note one of the 4 (The only One that shows on Network) has become the master browser.
Non domain environment.
I have seen various posts on this issues that sate that 6.2.3 fixed this problem can anyone help with this problem.
Kind regards, - euphosAspirantThe apparent "lock-up" appears to occur overnight when my Kodi backup add-in is trying to run.
- mdgm-ntgrNETGEAR Employee RetiredYes, they are exactly the same logs.
- euphosAspirant
mdgm wrote: There is an alternate method to download the logs using RAIDar 6.0 which you can try if the admin page isn't working.
Are these logs that same as those downloaded from the admin page? I used the RADar 6.0 way for the set of logs I send you today. - mdgm-ntgrNETGEAR Employee Retiredtviner1 please download your logs and send them to me(see the Sending Logs link in my sig). There is an alternate method to download the logs using RAIDar 6.0 which you can try if the admin page isn't working.
- tviner1AspirantUpdate to previous post - seems to fail after accessing 2nd folder in share:
Storage\ - displays full folder contents
Storage\Data - hangs and drops off network with no further access to admin page - tviner1AspirantAlso having problems with an RN104 post 6.2.4 upgrade.
Works long enough to browse shares and then goes offline.
Power button becomes unresponsive, doesn't respond to RAIDar and drops off network.
Removing power cord results in above recurring - no longer have access to files, although when checked with RAIDar there are no hard drive or other errors detected.
Tried from both Windows 7 and 8.1 machines, both with same result.
Did consider whether this could be a problem with the Antivirus App installed so tried removing it.
Shut down and restarted, but after trying to access folders went offline and non-responsive.
Starting to think about downgrading to 6.2.3 to rectify problem.
Noticed that there are other users here with same/similar problems and wondered whether there are any other setup changes worth considering in order to track the glitch down to a particular area - network/firmware/hd interface etc
