VolvoSkinn
Feb 09, 2016Aspirant
Getting status message Corrupt root
Hi. I have used my ReadyNas Ultra2 for something like 2 years. And now one HDD is broken. I changed it and then "Status: Corrupt root" Tryed OS reinstall --> and that diden´t work (same S...
Feb 10, 2016Guru - Experienced User
Try putting the drives into a PC, and zeroing them with the vendor disk diags (both seagate's seatools and wdc's lifeguard can do that in their "advanced" tests).
- VolvoSkinnFeb 10, 2016Aspirant
When i boot the RNDU 2 and press RESET. The led is behave as it is specefied.
I chose the factory deafault. Then press reset and i get a rebot.
Then i get this
After somehing like 30 sec the sound form the HDDs are gone.
And in the picture i have klick on setup. I can pick what ewer here. ( i have tryed them all )(3 different first expand vol recomended and the i tested RAID 0 and then, wht the **** i go whit the ERASE)
But allways i end up whit this. After aprox 20 sec
I cant access the IP adress in an internet browser. I cant se or communicate whit it in any way. I need to go to step one agan. And reboot over and over again. Please help me
IS it maby possibel to load / upgrade firmware from USB memory?
