lgottli
Feb 08, 2019Aspirant
glitches ReadyNAS Pro 6 (rndp6000) - keeps rebooting when network plugged in
I have a ReadyNAS pro 6, it has the laatest firmware release, running RAIDiator-x86-4.2.31. A little while ago the unit started to re-boot by itself constantly. It has been running flawlessly for man...
- Feb 08, 2019
The NAS NIC and the power on/off circuit share a power source called "+5VSB", which is +5 volts Standby and has a very small load limit. If the NIC is drawing too much power, that could glitch the power circuit. If that's the issue, it could be the NAS motherboard, but more likely is the power supply. The +5VSB is a common failure because it remains on even when the NAS is "off", since it has to power the on/off circuit for the button and the NIC for WoL to work.
You can try disabling WoL (Wake on LAN) and see if that helps. It probably won't for long, but it could give another clue.
Do you have a "spare" ATX power supply you can connect externally to your Pro6 to see if that resolves the issue?
Sandshark
Feb 09, 2019Sensei
Which supply did you get? Is the 24-pin cable long enough without an extender, and are there 3 4-pin Molex connectors?
Others occasionally ask for suggestions now that the Seasonic is no longer available, so I'm looking for a suggestion for them. I still have one Seasonic squirreled away.
lgottli
Feb 09, 2019Aspirant
I went with a really big guy from memory express. EVGA 650. It is a gold standard power supply so it is not cheap. For its size I am surprised how small. With such a small load on the supply, I double the fan will even kick in.
That has 4 molex connectors (4 pin power), only need 3. It also has 2 - 4 pin power connectors for the mb, only need the one.
No the ATX cable was about 3 inches too short, so I went and got an ATX extension cable. It fit in really well as it is physically the same size. A bit of a pain working with it but doable for anyone that is a bit handy. It isad they could have designed the board so the mb power connector was at the power supply end not totally on the other side.
It is also modular so you only plug in the 3 cables you need no extra wires everywhere.
- SandsharkFeb 09, 2019Sensei
Thanks. The Bronze 450 and 550 versions have been on my list, but I've been a bit hesitant to recommend that line since the fan is larger and there will be some restriction of it's flow. Good to know it's working for you.
Given the small cost difference between the 450 and 650, it makes sense to go with the big boy if you go for the gold version. The Bronze still have a 5 year warranty and are half or less the price, so many may want to go with them.
- lgottliFeb 09, 2019Aspirant
The fan opening is more or less right on. I was happy as there was not much of a restriction.
Notice fan is not even spinning as it is under not enough load to heat it up. That was another reason I went with a bigger supply.
Thanks for the picture. Not having actually purchased one, I pictured there being more fan restriction.
Unfortunately, I mis-spoke about the Bronze version. I thought it was EVGA that was on my list, but it's not. They do not seem to make a Bronze SFX supply.
Yes looking at the fan specs, I was concerned how much may be covered. But once I got it in there, and had a look, I was happy with the results. I don't anticipate problems with it. I think the fan sizes are including the case it is in? not necessarily the blade sizes. I think that is where I won. It is only millimeter coverage I am looking at, even that in a very small area.
