lgottli
Feb 08, 2019Aspirant
glitches ReadyNAS Pro 6 (rndp6000) - keeps rebooting when network plugged in
I have a ReadyNAS pro 6, it has the laatest firmware release, running RAIDiator-x86-4.2.31. A little while ago the unit started to re-boot by itself constantly. It has been running flawlessly for man...
- Feb 08, 2019
The NAS NIC and the power on/off circuit share a power source called "+5VSB", which is +5 volts Standby and has a very small load limit. If the NIC is drawing too much power, that could glitch the power circuit. If that's the issue, it could be the NAS motherboard, but more likely is the power supply. The +5VSB is a common failure because it remains on even when the NAS is "off", since it has to power the on/off circuit for the button and the NIC for WoL to work.
You can try disabling WoL (Wake on LAN) and see if that helps. It probably won't for long, but it could give another clue.
Do you have a "spare" ATX power supply you can connect externally to your Pro6 to see if that resolves the issue?
Sandshark
Feb 09, 2019Sensei
Thanks for the picture. Not having actually purchased one, I pictured there being more fan restriction.
Unfortunately, I mis-spoke about the Bronze version. I thought it was EVGA that was on my list, but it's not. They do not seem to make a Bronze SFX supply.
lgottli
Feb 09, 2019Aspirant
Yes looking at the fan specs, I was concerned how much may be covered. But once I got it in there, and had a look, I was happy with the results. I don't anticipate problems with it. I think the fan sizes are including the case it is in? not necessarily the blade sizes. I think that is where I won. It is only millimeter coverage I am looking at, even that in a very small area.
