cubewebsolution
Oct 26, 2011Aspirant
GS716T
Just wanting to know if the Netgear GS716T / GS716t V2 (http://bit.ly/rIOmVy) is compatible with the Netgear ReadyNAS Ultra 6+. It's not on the list. At the moment I have the GS116, and needing ...
mdgm-ntgr
Oct 26, 2011NETGEAR Employee Retired
Most switches particularly NetGear switches should work fine. I would try with what you have. If you have issues contact NetGear tech support for assistance.
A managed switch would be nice but is mainly of benefit if you have a business ReadyNAS (e.g. Pro 6) where you can use LACP rather than a home unit (e.g. Ultra 6+) which doesn't have NIC teaming.
