cubewebsolution
Oct 26, 2011Aspirant
GS716T
Just wanting to know if the Netgear GS716T / GS716t V2 (http://bit.ly/rIOmVy) is compatible with the Netgear ReadyNAS Ultra 6+. It's not on the list. At the moment I have the GS116, and needing ...
mdgm-ntgr
Oct 27, 2011NETGEAR Employee Retired
The Pro ships with enterprise drives. You could buy diskless and choose your own drives.
They are fairly similar. The HCL lists the compatible drives.
Business features include Rsync over SSH, snapshot (useful if data is going to be changing during backup and recommended for use with e.g. ReadyNAS Replicate), NIC Teaming (http://www.readynas.com/bonding_en-us), VLAN support, AD (Windows Domain) integration etc. If you're a home user you may not need many of these features (if any).
As for the CPU, if transcoding (converting on the fly to stream) video e.g. to an iPad, the Pro 6 can handle 1080p video whereas the Ultra 6 Plus can only handle 720p video.
The Ultra 6 Plus could well be right for you. I'm just wanting to make sure you're aware of the option of the Pro 6 and what it provides.
