cubewebsolution
Oct 26, 2011Aspirant
GS716T
Just wanting to know if the Netgear GS716T / GS716t V2 (http://bit.ly/rIOmVy) is compatible with the Netgear ReadyNAS Ultra 6+. It's not on the list. At the moment I have the GS116, and needing ...
mdgm-ntgr
Oct 27, 2011NETGEAR Employee Retired
Sounds like a good setup. I would go with the Pro 6.
Transcoding is useful for converting video for streaming to devices that can't handle (e.g. due to bandwidth limitations or limitations with the device) high quality video. It sounds like you're not doing any of that.
The CPU difference is explained in CPU Specs of the ReadyNAS
