claynz
Oct 15, 2023Guide
Hard Drive Upgrade RN314 NAS
Does this NAS unit support the Seagate ST22000NT001 harddrives?
- Nov 09, 2023
That's why I have the mirror copy of data on my computer as I do on my NAS.no need for redundancy
I am starting to download in 480p now quality is good and file size smaller.
Oct 15, 2023Guru - Experienced User
It should work with no issues.
There is no known size limit for disks that can be added to OS-6 systems. SMR disks don't work well, and should be avoided.
All ReadyNAS platforms are end-of-life, and Netgear has neglected the HCL for a long time. Best to not use it.
In general, I recommend enterprise class, or Ironwolf, WD Red Plus (but not WD Red, which are SMR).
FWIW, I suggest testing the drive in a Windows PC with Seatools before adding it to the NAS. Personally I run the full non-destructive test, followed by the full erase test. I have had some drives pass one of these tests, but fail the other. This will take a couple of days for a disk this large, but IMO worth the time.
