Bhushan
Dec 02, 2024Aspirant
Having RN212 and need to upgrade the Drives to 10TB
Dear Community, I would request you to please let me know if the available Model No. ST10000NM017B for Seagate 10TB will be compatible with ReadyNAS 212 as the below list doesn't show the model ...
Dec 03, 2024Guru - Experienced User
Bhushan wrote:
compatible with ReadyNAS 212 as the below list doesn't show the model no.
https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
The list hasn't been updated in a long time, so it is no longer a useful guide.
Any NAS-purposed (Ironwolf, WD Red Plus) or enterprise-class SATA disks is fine, so the current Ironwolf model you are thinking about is a good choice.
Bhushan
Dec 03, 2024Aspirant
Hi Stephen,
Thank you very much for your quick reply and update.
