KarlJNH
Dec 21, 2019Aspirant
Help installing Plex app
Hi all, I've been trying to install the Plex Media Server app on my ReadyNAS RN214 and I keep getting the error "Cannot install application plexmediaserver-annapurna". I got the app from the P...
Dec 21, 2019Guru - Experienced User
KarlJNH wrote:
I've seen posts about performing a factory reset but if I do will it wipe all data on my installed hard drives?
A factory reset will wipe all the data on the NAS.
KarlJNH wrote:
Hi all,
Is the NAS able to reach the internet? One way to check is to disable the automatic time upate, and then re-enable it. If the NAS can't reach the internet, the you will get an error when you renable it. If you have email alerts configured, you could send a test message to check the internet connectivity.
