MaartenPrins
Aug 06, 2016Aspirant
Help, readynas won`t startup anymore, Led 1 and 3 are on, power led is off
Hello all, A scream for help from the Netherlands. This afternoon I heard in my basement another sound then the sound I usually hear. It was the fan of my nas which was at full speed. Only ...
- Aug 14, 2016
Problem solved !
A friend of mine knew somebody who has exactly the same nas and firmware as my faulty nas has.
His nas has also 4 disks in X-RAID mode.
He made a backup of all his data and then we exchanged his disks for my disk.The nas did a normal boot and I could see my data (YES!)
I made a backup of my data and installed my disks in the nas I bought on e-bay.
Of course this will not happen me again so I bought directly some cloud storage.
Thanks for supporting me.
Regards, Maarten
MaartenPrins
Hi JennC,
Thanx for you quick response!
RAIDar doen`t find my nas anymore.
The lan connection of the nas is alive but i can`t find it in my network.
I already removed my disks (because of course i tried several times to start the nas which is not to good for my disks)
Also the lcd display at the frond doesn`t show anything at all.
What can i try to recover my nas?
Or is my only option find another one with the same firmware?
Maarten
mdgm-ntgr
Aug 07, 2016NETGEAR Employee Retired
It could be that you need to try more USB keys or perhaps some hardware in the NAS has failed.
There is a procedure for support to attempt to recover your data using a new ReadyNAS e.g. RN214/RN314. See http://kb.netgear.com/app/answers/detail/a_id/29875/~/readynas%3A-migrating-disks-from-raidiator-to-os-6
- MaartenPrinsAug 10, 2016Aspirant
Hello mdgm,
a few days passed by and I thought I found a readynas exactly the same on Ebay (RND 4xxx V2)
Well it is on the sticker but today the mailman brought me the package and first thing I noticed that this nas had a almost black housing (my faultly one is light gray)
I installed a small disk in the readynas and unfortunately after the reboot I had to descover it has raidiator 5.3.11 installed on it.
My faultly readynas had raidiator 4.1.xx installedSo maybe a new problem?
Of course I tried to startup with my 4 disks in the "new" nas, but that`s not working (as I was expecting)
Is there a possibility to migrate the X-RAID 2 disks from raidiator 4.1.xx to raidiator 5.3.11 ? Or is it only possible to migrate ro os6?
Regards, Maarten
- mdgm-ntgrAug 10, 2016NETGEAR Employee Retired
Your old NAS was a v1 perhaps v1 hardware rev 2.
No you can't migrate from the NV+ v1 to NV+ v2.
The procedure for migrating to an OS6 NAS does require remote assistance from support. You will need somewhere to backup your data to.
- MaartenPrinsAug 14, 2016Aspirant
Problem solved !
Regards, Maarten
