MaartenPrins
Aug 06, 2016Aspirant
Help, readynas won`t startup anymore, Led 1 and 3 are on, power led is off
Hello all, A scream for help from the Netherlands. This afternoon I heard in my basement another sound then the sound I usually hear. It was the fan of my nas which was at full speed. Only ...
- Aug 14, 2016
Problem solved !
A friend of mine knew somebody who has exactly the same nas and firmware as my faulty nas has.
His nas has also 4 disks in X-RAID mode.
He made a backup of all his data and then we exchanged his disks for my disk.The nas did a normal boot and I could see my data (YES!)
I made a backup of my data and installed my disks in the nas I bought on e-bay.
Of course this will not happen me again so I bought directly some cloud storage.
Thanks for supporting me.
Regards, Maarten
mdgm-ntgr
Aug 10, 2016NETGEAR Employee Retired
Your old NAS was a v1 perhaps v1 hardware rev 2.
No you can't migrate from the NV+ v1 to NV+ v2.
The procedure for migrating to an OS6 NAS does require remote assistance from support. You will need somewhere to backup your data to.
MaartenPrins
Aug 14, 2016Aspirant
Problem solved !
Regards, Maarten
