erhan75
May 21, 2016Follower
HELP with Ready nas NV+
Hi everyone, I' a newbie to the Netgear NAS scene and I recently got 2 Ready Nas units to replace my Dlink DNS323. The two units I got are 4 bays RND4000 V3 & RND4210 V3. Now the issue i'm having is...
DaneA
May 23, 2016NETGEAR Employee Retired
Hi erhan75,
As a follow-up, you may check the Hard Disk Compatibility List that you may want to use for both of your ReadyNAS NV+ (RND4000) here.
DaneA
NETGEAR Community Team
May 23, 2016Guru - Experienced User
In particular, disks > 2 TB in size are not compatible with your NAS. If you are looking for new disks, then I suggest the WD20EFRX or the ST2000VN000
The disk HCL that DaneA points to is very old, and personally I think you are better off ignoring it and getting a NAS-purposed disk.
