RPB123
Jun 06, 2020Aspirant
How can you tell if ReadyNas drive encryption is switched on?
How can one tell if the volumes in a Readynas have drive encrption turned on? I have inherited a ReadyNas 312 with firmware 6.10.3. Volume says it is X-Raid Raid1
Jun 06, 2020Guru - Experienced User
Is there a USB thumb drive connected to the NAS (which would be needed to hold the key if the volume is encrypted).
Is there any content on the volume that you care about?
