InterClaw
Feb 04, 2013Aspirant
How do I get dmidecode?
I want to check some details on the RAM in the NAS. I've seen dmidecode been mentioned. How do I get that on the ReadyNAS Pro 6?
InterClaw
Feb 05, 2013Aspirant
Sounds great! Will definitely try this out.
Just a couple of questions first though:
1. I can't find any info on this add-on on the site. Can you direct me to it?
2. Would this version be compatible with the Pro Pioneer as well?
