InterClaw
Feb 04, 2013Aspirant
How do I get dmidecode?
I want to check some details on the RAM in the NAS. I've seen dmidecode been mentioned. How do I get that on the ReadyNAS Pro 6?
mdgm-ntgr
Feb 05, 2013NETGEAR Employee Retired
1. The add-on includes BIOS updates for some ReadyNAS models. BIOS updates can be needed for a variety of reasons for different models.
2. There is no BIOS update available for your model. The add-on should detect that if you tried to install it.
Edit: 2. Yes, the Pro Pioneer/BE, Ultra 6 Plus and Pro 6 use the same BIOS
