lanceaustx
Nov 30, 2022Aspirant
How to open RAIDiator ".13" file type?
I am trying to install an old ReadyNAS RND2210 v2 on a new computer. I downloaded the RAIDiator-5.3.13 file from this site at https://www.netgear.com/support/product/RND2110v2.aspx#download and extra...
Sandshark
Nov 30, 2022Sensei
The .13 isn't an extension, it's just the last part of the version number. OS updates for that model don't have extensions, and you simply load it via the NAS user interface.
But be sure your unit really is a "V2". If it's currently running RAIDiator 5.x, then it is. But if it's running 4.1.x, then it's a V1 and cannot run 5.x. Netgear "re-used" the "V2" designation, making things confusing.
