lanceaustx
Nov 30, 2022Aspirant
How to open RAIDiator ".13" file type?
I am trying to install an old ReadyNAS RND2210 v2 on a new computer. I downloaded the RAIDiator-5.3.13 file from this site at https://www.netgear.com/support/product/RND2110v2.aspx#download and extra...
Nov 30, 2022Guru - Experienced User
lanceaustx wrote:
I am trying to install an old ReadyNAS RND2210 v2 on a new computer. I downloaded the RAIDiator-5.3.13 file from this site at https://www.netgear.com/support/product/RND2110v2.aspx#download and extracted the Zip file.
To add to Sandshark's comments - 5.3.13 is firmware for the Duo v2. It can't be installed on a PC.
Are you wanting to install RAIDar??? If so, the software is here:
Hal008
Dec 15, 2022Aspirant
Hi, came across this question as I'm also trying to setup an old NV+ V2 but after following this when it tries to open a web page I get the error
192.168.1.11 uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
I've looked up this but can't get a fix that works.
Any help would be appreciated.
- StephenBDec 15, 2022Guru - Experienced User
ERR_SSL_VERSION_OR_CIPHER_MISMATCHNote many owners of the original (sparc-based) NV+ mistakenly think they have a v2 (which is arm-based). Options for solving the mismatch problem are somewhat different, so it is important to be certain about the platform.
The original NV+ (called v1 here)
- runs 4.1.x firmware
- says ReadyNAS NV+ on the front panel.
- often has other labels that suggest it is a v2 or a v3.
The NV+ v2
- runs 5.x firmware
- says ReadyNAS NV+ v2 on the front panel.
- Hal008Dec 15, 2022Aspirant
Hi Stephen B
Thanks for the reply. I do have the NV+ V2 and running 5.3.....
The problem now is
1. windows doesn't see it ( LG TV and Denon media player see it but can't find anything on it)
2. I can't web into it ( that's the error I get)
I've only just found a video that recommends using CENT Browser and that now allows me to get to the login screen.
Now I have to just sort out my password.....
Thanks again
Go into "turn windows features on and off" and enable SMB/CIFS 1.0.
Now that you are in, you can install this add-on:
More details are in the thread I linked earlier. But this will update the web server in the NAS to use TLS 1.2. That will let you use any browser.
- lanceaustxDec 15, 2022Aspirant
I saw that error at one point as well. Unfortunately, I can't remember exactly how I solved it. But one thing I did was to change my RAIDar to a 64 bit in order to match the Java 64 bit environment I had. So you might double check yours match.
