LucicX
Jan 13, 2021Aspirant
How to set a ReadyNAS RND4250?
Hello there. I just put my hands on a second hand-rnd4250seems-to-be-working ReadyNAS RND4250. Didn't know that is an obsolete model and I thought that it would be a good idea to use it as a local f...
- Jan 18, 2021
Do you have internet security software running on the PC?
Jan 13, 2021Guru - Experienced User
LucicX wrote:
I believe that it has something to do with the Java.
No, the NAS web ui doesn't use Java.
Did you get a username/password prompt when you tried to access the web ui?
Also, what disks did you install?
LucicX
Jan 14, 2021Aspirant
Hi there, StephenB.
Thanks for the fast answer.
Under windows, every single browser that I use to access the interface looks similar with what I attached in the first post. Hence my believe that has something to do with java.
In the meantime, I managed to configure the NAS through an Ubuntu distribution, through the wizzard method.
Now I can access the drive content from my android phones and my tv, that are connected to the network.
But with Ubuntu still unaccessible.
Under Windows I managed somehow to "mount" the NAS in my computer, I can see it, I can access and read it but no write possibilty.
And when I want to access it from "network" window, it gives the already classic error 0x80004005 which, right now, I'm struggling to solve.
In the machine, I mounted an older 320gb hitachi drive, for test purpose. As I already said, I bought the NAS on second hand market and wasn't sure that it works. It seems that it does.
- StephenBJan 14, 2021Guru - Experienced User
FWIW, your NAS was introduced by Netgear in 2007, and discontinued in 2011. The final firmware was released in 2017. It is limited to 2 TB disks, and does not support SMB 2 or SMB 3. So with Windows 10, you will need to enable the SMB 1 client in order to access the network shares.
Speed is much slower than a modern NAS - it can deliver about 20 MB/s throughput for large file transfers.
I have one of these models that is still running - I use it as a secondary backup for my main NAS. It's been very reliable over the years, but it is too small and too slow to serve as my main NAS.
No java is used for the web interface (though there is java needed for RAIDar).
You should see a log-on popup, and after you log in as admin you should see something like this:
RAIDar should be able to tell you what firmware is on the NAS. If the firmware is very old, it might not be compatible with current browsers, so it would be useful to know what it is running. https://kb.netgear.com/20684/ReadyNAS-Downloads
- LucicXJan 14, 2021Aspirant
StephenB wrote:is limited to 2 TB disks, and does not support SMB 2 or SMB 3. So with Windows 10, you will need to enable the SMB 1 client in order to access the network shares.
Yeah, I discovered the `issue` during my research over configuration. Still struggling with SMB enabling. It seems that I succesfully did that, but it still won't connect.
I think I can live with that, for now. Don't think I need more speed for media streaming. And at copying files, that can be done over night, right?
Yeah, that is interface, in Ubuntu. In windows it just shows a bunch of `things`, as showed in the first post.
Any link to some infos about how to update the firmware? I read and followed the instructions from the manual, but nothing happened. It stays with version 4.1.6
Download 4.1.16 from https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc and extract the image from the zip file.
Then manually install it from the web interface (using the "local" tab):
You'll probably need to click through a registration offer to get to this page.
BTW, there were changes to the partitioning between 4.1.6 and 4.1.16. You need to do a factory reset after the update to get them. But since you'll be doing a factory reset anyway with the real disks, that's not a priority.
Check again on the admin web interface issue in Windows after you upgrade the firmware.
