LucicX
Jan 13, 2021Aspirant
How to set a ReadyNAS RND4250?
Hello there. I just put my hands on a second hand-rnd4250seems-to-be-working ReadyNAS RND4250. Didn't know that is an obsolete model and I thought that it would be a good idea to use it as a local f...
- Jan 18, 2021
Do you have internet security software running on the PC?
LucicX
Jan 18, 2021Aspirant
I updated the firmware to 4.1.16. The web interface in windows still looks weird and unfunctional as in the picture.
I managed somehow to map the network drive in my computer, but when I access it, I only have read privileges:
Still googling for solutions.
Jan 18, 2021Guru - Experienced User
- SandsharkJan 18, 2021Sensei
I have seen a similar instance with a corrupted Apache configuration file. In my case, it was something I did myself, and it's been far too olong since I was running a 4.1.x system to remember exactly which file it was. Try an OS re-install in case somethng went afoul with the OS update.
- LucicXJan 19, 2021Aspirant
StephenB wrote:Do you have internet security software running on the PC?
:)))) Yes, I have. I temporarily disabled it, and the interface is working. Thanks for the hint!
And I modified the security mode from "Share" to "User", defined a user with password and I have also write access to the NAS.
Thank you for your pacience and kind answers.
