theacoustician
Jul 24, 2010Aspirant
[How-to]Install Tonido on a x86 ReadyNAS device
I posted this over at the Tonido forums and I thought I'd post it here in case anyone was curious on how to do this. It seemed more appropriate to post here as opposed to th add-on section since it'...
super_poussin
Jul 28, 2010Virtuoso
I try it but it's a little bit Moreau complex to make it run.
For example the configuration file is created only after a first run
I will also try to run it as non-root user and relocate data
