theacoustician
Jul 24, 2010Aspirant
[How-to]Install Tonido on a x86 ReadyNAS device
I posted this over at the Tonido forums and I thought I'd post it here in case anyone was curious on how to do this. It seemed more appropriate to post here as opposed to th add-on section since it'...
theacoustician
Aug 19, 2010Aspirant
super-poussin wrote: typo corrected thanks
Question : what would you recommend as the best way to update? Can you run the updater from the Settings menu inside the program or would it be best to wait for you to compile a new .bin?
