theacoustician
Jul 24, 2010Aspirant
[How-to]Install Tonido on a x86 ReadyNAS device
I posted this over at the Tonido forums and I thought I'd post it here in case anyone was curious on how to do this. It seemed more appropriate to post here as opposed to th add-on section since it'...
theacoustician
Nov 05, 2010Aspirant
Ok, I've found a bug in the Tonido plugin and I think it might exist in this method too.
The Jukebox is broken. You cannot stream music. FFMPEG is used by Tonido to transcode and stream on the fly. However, if you check FFMPEG on your box...
The reason seems to be because libvorbisenc.so.2 missing. There may be other reasons, but this seems like the big one. The problem is that I can't seem to find a .deb for it. I've tried apt-get, but...
Using the -f swtich will force Tonido to uninstall and a few other things it would seem. I'm working on a solution, but if someone else can figure it out in the mean time, that would be swell.
mediavault:/usr/local/tonido/plugins/jukebox# ldd ./ffmpeg.exe
linux-gate.so.1 => (0xb7785000)
libz.so.1 => /usr/lib/libz.so.1 (0xb776a000)
libm.so.6 => /lib/libm.so.6 (0xb7744000)
libvorbisenc.so.2 => not found
libvorbis.so.0 => /usr/lib/libvorbis.so.0 (0xb771b000)
libpthread.so.0 => /lib/libpthread.so.0 (0xb7703000)
libc.so.6 => /lib/libc.so.6 (0xb75c5000)
/lib/ld-linux.so.2 (0xb7786000)
libogg.so.0 => /usr/lib/libogg.so.0 (0xb75c0000)
mediavault:/usr/local/tonido/plugins/jukebox# apt-get install libvorbisenc2
Reading package lists... Done
Building dependency tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
libfontconfig1: Depends: libfreetype6 (>= 2.3.5) but 2.2.1-5+etch3 is to be installed
Depends: fontconfig-config (= 2.6.0-3) but it is not going to be installed
tonido: Depends: libfreetype6 (>= 2.3.5) but 2.2.1-5+etch3 is to be installed
Depends: fontconfig (>= 2.4.2-1.2) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
