theacoustician
Jul 24, 2010Aspirant
[How-to]Install Tonido on a x86 ReadyNAS device
I posted this over at the Tonido forums and I thought I'd post it here in case anyone was curious on how to do this. It seemed more appropriate to post here as opposed to th add-on section since it'...
Tarv
Mar 01, 2012Aspirant
ScottChapman wrote: So...
Anyone know how to re-use a tonido account??
A newer version of Tonido is required before you can recover an account. The version installed with PRO-Tonido_1.2.bin does not have the recovery option.
Those without Root access will have to wait until a new install BIN is released. 8)
If you have root access, you can update manually. Disable the add-on from FrontView before you update.
wget http://www.tonido.com/download.php?TonidoSetup_i686.deb
dpkg --force-all -i TonidoSetup_i686.deb
Re-enable add-on after you update.
Recovery instructions: http://www.tonido.com/support/display/d ... count+name
