theacoustician
Jul 24, 2010Aspirant
[How-to]Install Tonido on a x86 ReadyNAS device
I posted this over at the Tonido forums and I thought I'd post it here in case anyone was curious on how to do this. It seemed more appropriate to post here as opposed to th add-on section since it'...
SergeB1
Jan 12, 2013Aspirant
Thanks for your instructions. I used them to install Tonido on ReadyNAs Pro2. I'm new to Tonido, but not new to UNIX.
I tryed to install Tonido before using adds-on, did not work for me. I removed everything and started from scratch.
Hoped, your instruction will do the trick. Nope.
Installation was smooth. No issues or errors. Tonid process "tonidoconsole" is running. Created new account. No issues. Have a login screen, but cannot login. Windows IE just hangs after password entered. iPhone displayed the meesage: "Failed to connect to server". Am I missing something ?
Your advice will be greatly appriciated.
SergeB :?
SergeB :?
