Jeroen1000
Aug 28, 2008Aspirant
HowTo make your Readynas more secure [nessus/ssl]
This HowTo is based on a RND 2150 with firmware 4.1.3-T136. It should work for other Readynas devices as well. A big thanks goes out to Chirpa for leading me the way :thumbsup: Before you get st...
Rocket_Man
Nov 26, 2010Guide
I am looking at this thread - 3 months on and no assurances given. I think the conclusion is that the Duo is an open window if you leave it visible from outside you are vulnerable and so is your data, This is a pity since it means you would need to be reckless to use e.g. ReadyNAS Remote. Until these holes are addressed, best not to make it visible at all saddly - close off your firewall/router and do not allow access from the internet.
Rocket Man
Rocket Man
