pixel81
Jun 01, 2013Guide
HOWTO: Prepare a 4TB GPT Drive for Duo/NV+ v2 USB3.0
After experimenting with a bare drive and USB3.0 docking station, I'm able to connect and use a 4TB Drive on a ReadyNAS NV+ v2 USB3.0 port :-D Here are the steps that were used. Notes: The drive...
jmurray1
Jun 14, 2014Aspirant
Perfect. This was just what I needed to partition and format my 8TB LaCie drive so that the ReadyNas would recognize and use it.
Too bad I couldn't ReadyNas couldn't do it natively. If parted was installed I could have done it from the command line, but no such luck.
