carlocki
Oct 23, 2022Luminary
I keep loosing credential access from pc to NAS. os reinstall only works
NAS r104 keep loosing access from pc if I reset os reinstall it works but I loose it 2 times a day. It is frustrating.
Oct 23, 2022Guru - Experienced User
carlocki wrote:
NAS r104
It is frustrating.
That is really strange. Are you sure the issue isn't on the PC end?
carlocki
I am thinking the same. do I have to change forums?
- StephenBOct 23, 2022Guru - Experienced User
I don't think so.
When you lose access from the PC, have you checked if you can access the web admin interface from the same PC?
- carlockiOct 23, 2022Luminary
StephenB wrote:
carlocki wrote:do I have to change forums?
I don't think so.
sometimes it works like this
accounts nas side?
Sorry, but I am not seeing what is wrong in this picture.
When you say you are losing - are you getting a password error, or is the NAS just not responding?
Have you tried restarting it (instead of doing an OS reinstall)?
