Grogu
Apr 05, 2023Guide
Install Debian 11 on ReadyNas 526x
As there are growing issues with Debian 8.x on ReadyNas ( see : https://community.netgear.com/t5/New-ReadyNAS-Users-General/ReadyNAS-628X-KEYEXPIRED-amp-Hash-Sum-mismatch-Debian-jessie ) I decided t...
Sandshark
Apr 08, 2023Sensei
The Debian installer does not have VNC built-in. I assume that he chose Centos in part because it does. For Debian, you could use preseeding (https://wiki.debian.org/DebianInstaller/Preseed) and then SSH in once it's installed to add VNC if you choose to use it instead of just SSH.
Grogu
Apr 09, 2023Guide
Not sure if I can install OMV on CentOs (I assume not) thus wonderin if I may connect via PCIe with video card to interact with Debian as here ( in japanese however google transtaors is good enough 🙂 ) :
https://www.cocoa.ne.jp/archives/6127
Thank you for your reply !
- SandsharkApr 09, 2023Sensei
On a 526x, I believe you can. I've never had my hands on one, but the photo of the rear looks like it has a PCI slot. But most ReadyNAS do not have a PCI slot, so not everyone could follow your lead.
- GroguApr 11, 2023Guide
Ok, I've just recieved connector (PCIe x16 >> PCIe x1) and was able to enter to 526x BIOS settings with my video card, and after pluging in USB I was able to select this USB as boot thus it seems that I'll be able to start with Debian installer from this USB.
Prior any changes I need to backup all my data 🙂
