kraeks
May 30, 2012Aspirant
Installing PHP5 on Readynas Duo v2 (should work on all ARM)
Since i'm not a big fan for paying for things that are easily done by myself, I thought i'd take the time to write down how i went about to install and configure PHP5, MySQL and phpMyAdmin on the Re...
- Jun 30, 2014
For the beginners like me, you can just buy https://rnxtras.com/addons/php-5-4-readynas-5-arm
Worked perfectly well on ma RND2000 ARM 5.3.10
:D
iearmand
Jul 17, 2012Aspirant
Can I ask a complete newbie question..but when you say "Go to your www-root and download the latest phpMyAdmin"
What do you mean by www-root...I cant find this anywhere and setting up a http service does not seem to help matters.
Also you may wish to correct the line of code below from:
to
sudo apt-get install mysq-serverl
to
sudo apt-get install mysql-server
