kraeks
May 30, 2012Aspirant
Installing PHP5 on Readynas Duo v2 (should work on all ARM)
Since i'm not a big fan for paying for things that are easily done by myself, I thought i'd take the time to write down how i went about to install and configure PHP5, MySQL and phpMyAdmin on the Re...
- Jun 30, 2014
For the beginners like me, you can just buy https://rnxtras.com/addons/php-5-4-readynas-5-arm
Worked perfectly well on ma RND2000 ARM 5.3.10
:D
Pafin
Jun 29, 2014Aspirant
Hey,
I have a ReadyNAS Duo v2 (Série: 2UM221E700702) with firmware RAIDiator 5.3.10..
Would this work on this config?
I'm totally newbie, I'm 17'000 km far from my readynas which I can access with the Remote. How can I access the root and where should I type these commands?
Thanks
Updated : I've installed Enable root SSH access. But still, I don't know what to do next...
Updated number 2 : Downloaded APT_1.0 from http://kb.netgear.com/app/answers/detail/a_id/12272, but I get the message : "Invalid update image" when I try to install the APT utility add-on.
Thanks
