Readybear
May 21, 2019Aspirant
Is exchanging two disks within an X-RAID2 array safe?
Hi there, first post on the Netgear Forum.
After a couple of years of light use my ReadyNAS Ultra 4 tells me there's a problem with disk 1 and I've lost redundancy. I have a suspicion that the...
Readybear
May 25, 2019Aspirant
Thanks for the reply.
When I boot the unit without any disks I get an error message and can't approach the unit with my browser. If I add a scratch drive I get another error: could not mount root RAID d. Makes sense.
Is it normal that the unit doesn't boot w/o any drives? Should I boot w/ the scratch drive and do a FACTORY REBOOT to be able to setup the unit w/ that. Will the Readynas Ultra 4 remember and recognize my precious RAID array later on? I'm really afraid of losing the whole array!
Last question: does the order of the drives in the array matter at all. I've numbered my drives and won't mess up but I'm just really curious about this.
May 25, 2019Guru - Experienced User
Yes. The system boots from the disks.
The operating system and configuration is installed onto the drives. So there is no benefit in using a scratch disk in this way.
The order shouldn't matter. But it is sometimes easier to troubleshoot if order is preserved - especially when disks are being swapped.
