leo037
May 29, 2023Luminary
Issue with hard drive upgrade and xraid
Hi everyone, Hoping someone can lend some help and maybe provide a solution. I am helping a friend out with her ReadyNAS. She's not big on being on forums or social media so relaying things f...
May 30, 2023Guru - Experienced User
leo037 wrote:
yes....
I'd be willing to take a look at the log zip - if she is ok with that, you should send them with a PM (private message). You do that using the envelope link in the upper right of the forum page.
The logs would need to be put into cloud storage (dropbox, google drive, etc), with a download link in the PM.
There is some privacy leakage - if email alerts are configured, I'd see the email address, for example.
leo037
May 30, 2023Luminary
sent you a message
- StephenBMay 30, 2023Guru - Experienced User
leo037 wrote:
sent you a message
Thx.
One aspect here - the system has been expanded several times. The original disks were 4 TB, with later expansions to 6 TB, 10 TB, and now 16 TB. As a result, the system has 4 different RAID groups in the data volume - md124, md125, md126, and md127. These are all concatenated together to form the data volume. When you replace a disk, all of these groups need to be resynced.
Physically, each of these groups has a corresponding partition on each disk. Looking at disks 1-5 (sda-sde), these partitions look like this:
Number Start (sector) End (sector) Size Code Name 1 64 8388671 4.0 GiB FD00 2 8388672 9437247 512.0 MiB FD00 3 9437248 7814033072 3.6 TiB FD00 4 7814033080 11721045119 1.8 TiB FD00 5 11721045120 19532873679 3.6 TiB FD00 6 19532873680 31251759055 5.5 TiB FD00(The first two partitions are for the OS and swap, and not part of the data volume).
But the final partition (number 6) has not been created on disk 6 (sdf). The serial number is 2BKLVLET
Number Start (sector) End (sector) Size Code Name 1 64 8388671 4.0 GiB FD00 2 8388672 9437247 512.0 MiB FD00 3 9437248 7814033072 3.6 TiB FD00 4 7814033080 11721045119 1.8 TiB FD00 5 11721045120 19532873679 3.6 TiB FD00It is also missing from RAID group md127:
md124 : active raid5 sda5[6] sdf5[11] sde5[10] sdd5[9] sdc5[8] sdb5[7] 19528915840 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU] md125 : active raid5 sda4[6] sdf4[11] sde4[10] sdd4[9] sdc4[8] sdb4[7] 9766874560 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU] md126 : active raid5 sda3[6] sdf3[11] sde3[10] sdd3[9] sdc3[8] sdb3[7] 19510833920 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU] bitmap: 0/30 pages [0KB], 65536KB chunk md127 : active raid5 sda6[0] sde6[4] sdd6[3] sdc6[2] sdb6[1] 23437242368 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/5] [UUUUU]Since the system is running FlexRAID (RAID-5), all the RAID groups need to include all the disks in order for the system to expand.
There's not enough info in the log zip to see why this partition wasn't created, and then added to md127. But the disk does appear healthy.
I suggest removing the disk, and connecting it to a PC. From there, you can either unformat the disk (deleting all the "volumes" on it using the Windows disk manager), or just format it. Then you can add it back to the NAS. If you choose to reformat it, then you will then have to format it again in the NAS before the system will add it back to the data volume.
- leo037May 30, 2023Luminary
OK thanks!
I'll see what she says and what happens.- SandsharkMay 30, 2023Sensei
Hmm, that only accounts for 6 of the 8 drives, so something more is wrong. Are you sure it's 8 drives and was 8 before swapping any? If it were 8, it should already have been RAID6 under XRAID.
I think I can understand why the last drive (which from the information given should be the 8th, not the 6th) didn't get the last partition and didn't get added to the RAID. At that point, the unit was in FlexRAID. And FlexRAID expects to operate on all drives at the same time, not incrementally as with XRAID. So, it didn't know what to do with that lone drive. But all but that last one should have been added to the volume as the drives were replaced in XRAID. The information StephenB posted seems to indicate that they were. But maybe the OS is confused since that last expansion didn't take place.
As StephenB said, the volume is expanded, it just didn't (fully) expand this time. So the message that you can't go from FlexRAID to XRAID with an expanded volume is appropriate (to the extent that's a limitation of the OS).
