Krishgrad
Jan 01, 2017Aspirant
Itune server
I have enabled the itune server and also enable network access on share folder. But still i cannot see the library on itunes. Please help.
Krishgrad
Jan 02, 2017Aspirant
Model ready nas 31200
With OS 6.6.0
I was trying to access a shar folder named - Media .
I was trying to access it on itune app from my surface pro 4 ( window 10 ).
Thank you for replying
With OS 6.6.0
- FramerVJan 03, 2017NETGEAR Employee Retired
Hi Krishgrad,
I see, I was thinking that you might have been using your home folder for the iTunes location.
Say, you are just accessing the ReadyNAS shares? Do you have access to it?
Also, I noticed that the BETA firmware has an included release regarding iTunes ([Beta 1] Added automatic recovery of bad iTunes server media databases). Although I cannot guarantee that it will fix it, you could try this or if not; wait for the official release.
ReadyNASOS 6.6.1-T230 (Beta 4)
- JennCJan 06, 2017NETGEAR Employee Retired
Hi Krishgrad,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
