TechZ1
Apr 04, 2011Aspirant
Kingston KVR333X64SC25/1G 1GB DDR1 / PC 2700 / DDR 333
Just bought 1x 1GB stick of Kingston Value RAM, Model: KVR333X64SC25/1G Type: SO-DIMM Shows up perfectly as: Memory: 1024 MB [2.5-3-3-7] NAS: ReadyNAS NV+ [X-RAID] Firmware: RAIDiator 4.1....
ChrisMc73
Aug 10, 2011Aspirant
fbmachines wrote: Try the Corsair VS1GSDS333 stick. I've had good success with that model and it's $10 cheaper than the Kingston model at Newegg.
Is this the stick you are referring to?
http://www.newegg.com/Product/Product.a ... VS1GSDS333
I recently sent a defective NV+ back to Netgear and left my 1GB Crucial stick in there, not sure I can recover it, I've sent off emails to try.
In the mean time I'm looking at the replacement stick if I need to get one, so you are saying this Corsair stick has worked in your NV+?
