TechZ1
Apr 04, 2011Aspirant
Kingston KVR333X64SC25/1G 1GB DDR1 / PC 2700 / DDR 333
Just bought 1x 1GB stick of Kingston Value RAM, Model: KVR333X64SC25/1G Type: SO-DIMM Shows up perfectly as: Memory: 1024 MB [2.5-3-3-7] NAS: ReadyNAS NV+ [X-RAID] Firmware: RAIDiator 4.1....
Tennessee_Slim
Nov 16, 2012Aspirant
The 1GB Kingston KVR400X64SC3A/1G SODIMM in my NV has died. When I upgraded from 256MB, I kept the OEM SODIMM, so I could revert to that, but I also have one stick of Kingston KVR333X64SC25/1G I bought a few years back.
I tried out the KVR333 (which isn't on the HCL) when I first bought it, but the NAS was having periodic lockups so I replaced it with the KVR400 (which is on the HCL). It's run flawlessly ever since but it was the KVR400 that failed last night.
I had kept the KVR333, and used it to diagnose the failed KVR400. The NAS is running fine on the KVR333 at the moment, showing timings of [2.5-3-3-7]. I don't fancy having any more graceless shutdowns, but I'd also rather be on the 1GB SODIMM than the OEM 256MB.
So long story short, the lock-ups I was having with the KVR333 were five years (and many RAIDiator revisions) ago. And five years on, you guys seem to be having good success with the KVR333. Is it possible that those lock-ups might have been related to the old firmware, and that the new RAIDiator(s) cure the problem I was having earlier with the KVR333?
If there is no correlation, which is to say the lock-ups had nothing to do with the version of the firmware, I'd sooner go back to the OEM 256MB SODIMM and not risk any data corruption. Yeah, I could just wait and see but you only get to dodge the bullet so many times before it finally hits you in the tooches, and I'd rather not risk it.
TIA for your advice.
